Hot to access two nodes outputs as input in code node?
Not able to access two nodes output as input in code node.
Hey @Hareesh_Kumar hope all is good.
If you want to send output of two nodes into a single code node, you probably want to merge the inputs first into a single item with combine(or multiple items with append) first and then process this item in the Code.
Thank you so much…
