How do i change my telegram webhook url to https, im hosting locally and using nodejs
my node telegram on message gives me this error:
Telegram Trigger: Bad Request: bad webhook: An HTTPS URL must be provided for webhook
IF you need to have an https endpoint for telegram to register the webhook, you could use a service like NGROK, please see this video for details:
Perfect, u r a lifesaver, or alot of countless hours. Thank you so much!!!
You are very welcome.
If that was helpful, kindly mark the answer as solution. Thank you.
Cheers!
i’ve managed to get the url to be https using ngrok but telegram stiill throws me the same error Telegram Trigger1: Bad Request: invalid webhook URL specified
Hey @Daniel_Kyeat hope your day is going well.
is not the same as the original
completely different error.
Could you share:
  • what your WEBHOOK_URL env var is set to?
  • what Webhook URLs are from the Telegram Trigger node (expand the top section).
Hello @jabbson i have found the solution to the problem in this link
I made an error of not changing the port details when setting up the static domain
Thank you so much for the follow up tho :slight_smile:
