❓ Telegram Trigger gives “HTTPS webhook required” error even with ngrok HTTPS URL
I’m trying to use the Telegram Trigger node in n8n while running it locally with ngrok. I have ngrok running and forwarding correctly from an HTTPS address to my localhost port (5678), but I’m still getting the “An HTTPS URL must be provided for webhook” error when trying to activate the workflow.
Workflow could not be activated:
Bad Request: bad webhook: An HTTPS URL must be provided for webhook
Here’s a screenshot of the error and my Telegram Trigger node settings:
Telegram trigger node setup
error i get when testing the trigger
:camera: ngrok running:
n8n version: Latest (installed via npm on macOS)
Database: SQLite (default)
n8n EXECUTIONS_PROCESS setting: Default (own)
Running n8n via: npm + ngrok (CLI)
Operating system: macOS 12+
WEBHOOK_URL=>>Ngrokurl<< n8n start
u must start n8n like this
@SlimeBswervin This works. great. thank you.
