How I Built JARVIS with No Code (Tutorial w/ Lovable, ElevenLabs, n8n)
Create your own Jarvis with Lovable, ElevenLabs and n8n
Ever wanted your own AI assistant like JARVIS from Iron Man? In this tutorial, I’ll show you how to build one using Lovable AI, ElevenLabs, and n8n—all without writing a single line of code!
You’ll learn how to create the interface with Lovable, connect the voice agent with ElevenLabs, and build the tool-calling workflow in n8n. By the end, you’ll have your own voice-powered AI assistant ready to use. All the resources you need are linked in the description, so you can follow along and build it yourself.
