How to configure SEO data for Article, I use Yoast Seo plugin.
How do I populate this data from the yoast panel with data generated by articles?
You cannot directly manipulate Yoast meta data using neither n8n nor the WordPress REST API. **The Yoast REST API is currently read-only.
so it is not possible to fill this data? will I have to do it manually after the article is posted?
Hey @Edgard_Neto
You can use the MySQL node to modify the Yoast meta_keys in the database, after you have created the post with n8n.
Once you have the post ID of the post, you can look up in the wp_postmeta
table, the meta_keys starting with _yoast
that belong to the post ID just generated.
SELECT * FROM `database_name`.`wp_postmeta` WHERE (`meta_key` LIKE '%_yoast%') AND (`post_id` LIKE '%12705%') ORDER BY `meta_id` LIMIT 500 OFFSET 0;
Wow! Will try for sure.
Awesome, I’ll take the test.
Thanks!
