How can I create google spreadsheet with first row as header key such as
R0C0- header1
R0C1-header 2
Hey @jay.singh, check out this example:
Simply create a fresh sheet before running the operation from the above example and you should be good to go.
New Google Sheet node is quite different from the older version and appears to be more sophisticated. To be able to add headers to the new spreadsheet I have come up with the following solution
Hopefully it is helpful.
