How to get personal settings from trigger function in custom node
I am building a custom node and i would like to get the peronal settings data like email while the trigger function is executed. is it possible? if not there is any other approach to inject this kind of data
  • **n8n version:latest
  • **Database (default: SQLite):postgres
  • **Running n8n via (Docker, npm, n8n cloud, desktop app):npm
Hi @mtubul :wave: Maybe @marcus or @jon could help you out here :slight_smile:
Hi @mtubul,
what do you mean by getting peronal settings data like email. If you are talking about user emails within n8n, these values are not accessible from within node implementations.
All data you are reading from should be either node or credential properties, where you could require a user to enter an email adress within the node configuration.
Got it, thanks for the clarrification.
