How to send a PNG for background removal API (PhotoRoom)
When running the flow and doing a POST request to the endpoint I get back:
“ERROR: Cannot create property ‘x-api-key’ on string ‘form-data; name=“image_file”; filename=Webbplats1_2023-08-12 15:13:05.png’”
API Reference
Stack
TypeError: Cannot create property 'x-api-key' on string 'form-data; name="image_file"; filename=Webbplats1_2023-08-12 15:13:05.png'
    at Object.execute (/usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes/HttpRequest/V2/HttpRequestV2.node.js:833:61)
    at Workflow.runNode (/usr/local/lib/node_modules/n8n/node_modules/n8n-workflow/dist/Workflow.js:646:28)
    at /usr/local/lib/node_modules/n8n/node_modules/n8n-core/dist/WorkflowExecute.js:631:53
  • n8n version: 1.0.4
  • n8n EXECUTIONS_PROCESS setting (default: own, main): own, main
  • Operating system: n8n cloud
Hi @Profit_Media :wave: This sounds like you’re not sending over the API token correctly. Can you take another look at your authentication settings? (Please don’t post screenshots with those details here :see_no_evil: Or you’ll need to rotate all your keys! )
Hmm
the value is formatted without bearer exacly as:
xxxxxxxxxxxxxxxxxxxxxxxxxxxxxx
Hi @Profit_Media - I more meant details that might contain the api key value :sweat_smile:
Did you try to edit the value there and double check the API key is correct?
Thank you for your quick reply, yes, checked it like 34 times.
It works in the playground
but n8n gives
So I just signed up for an account to see if I could successfully make a request, and had no problems doing so with this workflow:
You might be using an older version of the HTTP Request node - Photoroom’s API suggests sending the binary data in the image_file field, which your version of the node won’t let you specify.
In a more recent version of the node, you can specify the Form Data, like so:
Which then gives you a successful request :smiley: Can you try either using the workflow I posted as a base, or maybe remove the current HTTP node you have and re-add it through the node menu (instead of copying and pasting from an older workflow)? That might fix this up!
You did it !
It was the data part that did it because now it’s working with the same saved credentials.
Somehow the GET account info isnt still working but the task is accomplished. Thank you!
