How to use a nested split in batches?
Hello,
I’m wondering how to use nested split in batches.
The first function generates 10 items, the second function 5.
Now, I’d hoped that Set1 gets executed 50 times.
How to achieve this?
  "nodes": [
	  "parameters": {},
	  "name": "Start",
	  "typeVersion": 1,
	  "position": [
		300,
		280
	  "parameters": {
		"functionCode": "const newItems = [];\n\nfor (let i=0;i<10;i++) {\n  newItems.push({json:{i}});\n}\n\nreturn newItems;"
	  "name": "Function",
	  "position": [
		500,
		280
	  "typeVersion": 1
	  "parameters": {
		"batchSize": 1,
		"options": {}
	  "name": "SplitInBatches",
	  "type": "n8n-nodes-base.splitInBatches",
	  "position": [
		700,
		280
	  "typeVersion": 1
	  "parameters": {
		"conditions": {
		  "boolean": [
			  "value1": true,
			  "value2": "={{$node[\"SplitInBatches\"].context[\"noItemsLeft\"]}}"
	  "name": "IF",
	  "type": "n8n-nodes-base.if",
	  "position": [
		1460,
		810
	  "typeVersion": 1
	  "parameters": {
		"keepOnlySet": true,
		"values": {
		  "string": [
			  "name": "Message",
			  "value": "No Items Left"
		"options": {}
	  "name": "Set",
	  "type": "n8n-nodes-base.set",
	  "position": [
		1670,
		810
	  "typeVersion": 1
	  "parameters": {
		"functionCode": "const newItems2 = [];\n\nfor (let i=0;i<5;i++) {\n  newItems2.push({json:{i}});\n}\n\nreturn newItems2;"
	  "name": "Function1",
	  "position": [
		900,
		450
	  "typeVersion": 1
	  "parameters": {
		"batchSize": 1,
		"options": {}
	  "name": "SplitInBatches1",
	  "position": [
		1100,
		450
	  "typeVersion": 1
	  "parameters": {
		"values": {
		  "string": [
			  "name": "id",
			  "value": "={{$node[\"SplitInBatches1\"].json[\"i\"]}}"
		"options": {}
	  "name": "Set1",
	  "position": [
		1170,
		810
	  "typeVersion": 1
  "connections": {
	"Start": {
	  "main": [
			"node": "Function",
			"type": "main",
			"index": 0
	"Function": {
	  "main": [
			"node": "SplitInBatches",
			"type": "main",
			"index": 0
	"SplitInBatches": {
	  "main": [
			"node": "Function1",
			"type": "main",
			"index": 0
	"IF": {
	  "main": [
			"type": "main",
			"index": 0
			"node": "SplitInBatches1",
			"type": "main",
			"index": 0
	"Function1": {
	  "main": [
			"type": "main",
			"index": 0
	"SplitInBatches1": {
	  "main": [
			"node": "Set1",
			"type": "main",
			"index": 0
	"Set1": {
	  "main": [
			"node": "IF",
			"type": "main",
			"index": 0
Hey @Chris7935!
Welcome to the community :sparkling_heart:
I have updated your workflow and it now splits the data in the nested Split In Batches node correctly.
In the nested Split In Batches node I am using the Reset parameter. This parameter resets the value allowing the node to split values for the next items.
I hope this helps :slight_smile:
It work Thank
