How to use nodejs require module
When using a Code node, checking the current __dirname shows that it’s /usr/local/lib/node_modules/n8n/node_modules/n8n-nodes-base/dist/nodes.
However, when checking console.log('resolve-path: ', path.resolve()), it shows resolve-path: /home/node.
Although the file /home/node/modules/test/TestNode.node.js exists, I get an error saying it cannot be found when trying to require it.
The console.log('relativePath: ',fs.existsSync(path.resolve(relativePath,‘modules/test/TestNode.node.js’))) shows relativePath: true, meaning the file exists at the constructed path.
I’m using a local Docker setup.
Is there any way to import user code using require?
Cannot find module ‘/home/node/modules/test/TestNode.node.js’ [line 16]
  • n8n version: : 1.77.3
  • Database (default: SQLite):: default
  • Running n8n via (Docker, npm, n8n cloud, desktop app): : docker
  • Dockerfile
FROM node:20-alpine AS builder
# pnpm 설치
RUN npm install -g pnpm
WORKDIR /app
COPY ./package*.json ./pnpm-lock.yaml* ./
RUN pnpm install --frozen-lockfile --prod
FROM n8nio/n8n:latest
ENV NODE_FUNCTION_ALLOW_EXTERNAL=*
ENV NODE_FUNCTION_ALLOW_BUILTIN=*
USER node
COPY --from=builder --chown=node:node /app/node_modules /usr/local/lib/node_modules
COPY --chown=node:node ./modules /home/node/modules
WORKDIR /home/node
ENTRYPOINT ["n8n"]
  • docker-compose.yml
services:
  n8n:
    build:
      context: .
      dockerfile: Dockerfile
    restart: always
    ports:
      - "5678:5678"
    environment:
      - N8N_HOST=localhost
      - N8N_PORT=5678
      - N8N_PROTOCOL=http
      - WEBHOOK_URL=http://localhost:5678/
      - GENERIC_TIMEZONE=Asia/Seoul
      - TZ=Asia/Seoul
      - N8N_BASIC_AUTH_ACTIVE=false
      - N8N_BLOCK_ENV_ACCESS_IN_NODE=false
      - NODE_FUNCTION_ALLOW_BUILTIN=*
      - NODE_FUNCTION_ALLOW_EXTERNAL=*
      - N8N_DIAGNOSTICS_ENABLED=true
      - NODE_TLS_REJECT_UNAUTHORIZED=0
    volumes:
      - n8n_data:/home/node/.n8n
      - ./modules:/home/node/modules
      - ./n8n_data:/home/node/data
      - /etc/ssl/certs:/etc/ssl/certs
    env_file:
      - .env
volumes:
  n8n_data:
    external: true
Welcome to the community @ngionicc!
Tip for sharing information
Pasting your n8n workflow
<your workflow>
Here’s an example of using external modules
const { createHmac } = require('crypto');
const moment         = require('moment');
const secret = 'abcdefg';
const hash = createHmac('sha256', secret)
               .update('I love cupcakes')
               .digest('hex');
const d = moment().subtract(10, 'days').calendar();
return { hash, d };
If you are self-hosting, you would list the modules you want to use with environmental variables as per Enable modules in Code node | n8n Docs.
