HTTP Request Module Not Passing Authentication
Generic Credential Authentication failing with HTTP Request Node, but working if manually specified in the Headers.
Creating it by hardcoding the Authorization Header with Bearer token works fine and returns the expected output.
Authorization failed - please check your credentials
No output.
  • n8n version: 1.91.2
  • Operating system: N/A
Try the generic header auth type instead.
Same…HTTP Request auth broke. (maybe with the last update 1.91.2?) Using Authentication None, sending Headers seems to work.
