I Built an Automation That Runs My Blog and Promotes It While I Sleep
In this video, I’ll show you how I built a fully autonomous AI system that writes, designs, SEO-optimizes, and posts full blog articles — and then promotes them to 7 social platforms — completely on autopilot.
:brain: The system uses n8n, Airtable, OpenAI, and the Blotato API to:
• Pull keyword ideas from Airtable
• Generate SEO-optimized blog content & metadata
• Create AI-generated featured images
• Auto-publish to WordPress
• And post across Instagram, X (Twitter), LinkedIn, Facebook, Threads, and Pinterest
What do you think ?
Thank you for sharing your workflow I am trying it on my personal website. One question, can we pull keyword ideas directly from Ahrefs as per their search volume?
With some modification, I’m sure you can extract all also the keyword ideas.
This is a really interesting use case and a good example of how automation can go beyond simple task scheduling. I like that the workflow focuses on connecting multiple stages of the content process instead of automating only publishing.
Running blog operations automatically, content handling, distribution, and promotion, can save a huge amount of time and make consistency easier to maintain. The biggest value here isn’t just posting while you sleep; it’s reducing repetitive work, so more energy can go into strategy, quality, and improving content.
One thing I’d be careful about is adding checkpoints for quality control. Fully automated publishing can sometimes create issues with formatting, duplicate messaging, broken links, or content that doesn’t match audience expectations. A lightweight review step or analytics feedback loop could make the system even stronger.
I’d also be curious to know which parts produced the biggest impact, content generation, scheduling, social distribution, SEO updates, or performance tracking. Metrics like engagement, click-through rate, and time saved would make the results even more useful for others trying to build something similar.
