I Built an invoice workflow with validation, review routing, and duplicate protection
I built an invoice-intake workflow in n8n that goes beyond simple AI extraction.
It takes a PDF invoice and extracts vendor, invoice number, dates, totals, PO number, payment terms, and line items, validates required fields, checks arithmetic consistency, routes questionable invoices into a separate Review queue, stores clean invoices separately, blocks duplicate inserts using vendor + invoice number
The design principle is simple: AI extracts, deterministic logic validates.
I packaged the workflow with setup instructions, test invoices, troubleshooting, and internal n8n Data Table storage.
I built it because I wanted something that would not silently trust every AI extraction result.
Product page: Invoice Intelligence for n8n
Happy to answer questions about the workflow structure or validation logic.
Hi! I saw your invoice-validation workflow and your invitation to ask questions. I’m testing an early arithmetic-checking prototype and researching whether there’s an unmet need before developing it further.
Could you describe the last invoice your workflow needed someone to correct manually? What did the existing checks miss, how long did resolving it take, and does that happen regularly?
If you’ve tried another tool to solve it, what still falls short? No client documents or private information needed. Thanks for any insight!
