I have some problems with the webhook custom node
I encountered a problem. I want to customize a webhook node and a response node.
I defined the following webhook node:
  webhooks: [
		httpMethod: 'POST',
		path: 'wechat',
		responseMode: 'responseNode',
	async webhook(this: IWebhookFunctions): Promise<IWebhookResponseData> {
		return {
			workflowData: [this.helpers.returnJsonArray(data)],
When I call this.sendResponse(response) in the response node, an error is reported
Error: Cannot set headers after they are sent to the client
at ServerResponse.setHeader (node:_http_outgoing:655:11)
at ServerResponse.header (/usr/local/lib/node_modules/n8n/node_modules/express/lib/response.js:794:10)
at ServerResponse.json (/usr/local/lib/node_modules/n8n/node_modules/express/lib/response.js:275:10)
at Object.sendErrorResponse (/usr/local/lib/node_modules/n8n/dist/response-helper.js:98:32)
at WebhookRequestHandler.handleRequest (/usr/local/lib/node_modules/n8n/dist/webhooks/webhook-request-handler.js:69:35)
at /usr/local/lib/node_modules/n8n/dist/webhooks/webhook-request-handler.js:120:9
Then I tried to add noWebhookResponse: true in the webhook node
But the request was blocked and kept waiting for the response.
