Ideas on how to pin a tool output
Currently seems that there’s no way to pin the output of an AI Agent tool. I found this feature request but it seems forgotten.
From my point of view it seems a very straightforward feature and actually counter-intuitive that it’s not available even for the “Call n8n workflow tool”. I mean, we can pin data by calling this same workflow with the “Execute a sub-workflow” node, but we cannot pin when using the same workflow as a tool.
Sometimes a tool processing takes a lot of time and might consume a lot of resources, so I’m wondering if someone has an idea on how to tests this tools? Do you create a “mock” tool or something like that? Any other suggestion?
Workaround for testing and development is to use data mocking or manual pinning in other nodes, but not directly on the tool output itself…
@Parintele_Damaskin Thanks for answering! I tried that during this last weeks and that’s certainly very cumbersome. I think my only option here is to wait for the feature
