I have a simple flow where I am getting getting customer and sales data from a CRM system.
Depending on whether this is the first purchase from this customer or not (comparing the date of the purchase and the date the customer was created), I want to send the customer data to one webhook or another.
I tested the workflow and it works fine for a new customer. However, for an existing customer that made a new purchase, the If node is not passing the data to the following HTTPS node.
I get “no input” even though this is the false branch in the If node:
As a result, the https node for existing customer sends no data to the webhook.
Any idea of what I am doing wrong? I actually copied this workflow from another that works fine.
- n8n version: 1.49.0
- Database (default: SQLite): sqlite
- n8n EXECUTIONS_PROCESS setting (default: own, main): main
- Running n8n via (Docker, npm, n8n cloud, desktop app): docker
- Operating system: ubuntu
