Had this really simple script working for a while and all of a sudden it only triggers the false branch .. regardless of the input (could also be true or false).
Hey @daniello,
Thanks for creating a separate topic!
Is the data type of the value you pass in the Value 1 field boolean or string?
Hey @daniello,
I checked the workflow that you shared here: 0.134.0 Mqtt Trigger broken - #6 by daniello
I tested it and I got the following result
If you observe, the value in the message that I get is a string. To get the boolean, you should enable the JSON Parse Body additional option. This will return the values with the right data type. You can then refer to the value in the IF node.
Here’s the output with the JSON Parse Body option.
Here’s the updated workflow
Ah … forgot to press save the first try … thought this was auto-save. Seems to work now with that option … let me do some more tests.
- Deactivate the workflow and delete all pushover messages
- I activate the workflow → 2 true pushover messages (true is correct, 2 is incorrect)
- I send false → 1 false message
- I send true → 1 true message
Nr. 2 is a separate ticket … plus it bounces (why 2 messages).
Thanks so far!
(I wonder why my script formerly worked)
