Good afternoon.
I have the following problem:
Error: read ECONNRESET
at TCP.onStreamRead (internal/stream_base_commons.js:205:27)
Emitted ‘error’ event on ImapSimple instance at:
at Connection. (/usr/lib/node_modules/n8n/node_modules/imap-simple/lib/imapSimple.js:39:14)
at Connection.emit (events.js:310:20)
at TLSSocket._onError (/usr/lib/node_modules/n8n/node_modules/imap/lib/Connection.js:151:10)
at TLSSocket.emit (events.js:310:20)
at TLSSocket._emitTLSError (_tls_wrap.js:873:10)
at JSStreamSocket. (_tls_wrap.js:805:36)
at JSStreamSocket.emit (events.js:310:20)
at Socket. (internal/js_stream_socket.js:58:38)
at Socket.emit (events.js:310:20)
at emitErrorNT (internal/streams/destroy.js:92:8) {
errno: ‘ECONNRESET’,
code: ‘ECONNRESET’,
syscall: ‘read’,
source: ‘socket’
Can you help me with this?
