Dear Community,
I thought there has been need of Claude pro based model in N8n. Existing nodes require Claude Code to be installed on the server.
I have created Custom Node - https://www.npmjs.com/package/n8n-nodes-claude-pro You can use long lived Claude token generated using claude setup-token
I have tested basic functionality and it works. However if you find any issue, then do not hesitate to report it on Github please GitHub - chynten/n8n-nodes-claude-pro · GitHub
Thanks
