Is it possible to bundle a group of nodes into a reusable snippet?
Hi all,
New user to n8n and I’m fairly certain I’m missing something basic here. Sorry in advance.
I have a workflow where I have multiple paths, and I’d like to add a set of nodes to each path ( these nodes are to work around Notion’s 2k character insert limit ).
Ideally, I’d have 1 main snippet/template with an instance of it on each of these unique paths. That way if I update the main snippet, all of its instances update, too.
Is this solved by creating a separate workflow for the Notion workaround, then calling it and returning its output into the existing workflow?
Information on my n8n setup
  • n8n version: 1.50.1
  • n8n EXECUTIONS_PROCESS setting: own, main
  • Running n8n via: n8n cloud
Hi Jamey! You can achieve this with Sub-workflows:
Looking into this now. Thank you @bartv !!
