n8n build with docker image custom fails either with
missing openapi.yml
or during the build in on the clean up step rm-rf …
the openapi issue
8bb03 “{ file: ‘LicenseManager.js’, function: ‘log’ }”
Error: ENOENT: no such file or directory, open ‘/usr/local/lib/node_modules/n8n/packages/cli/dist/PublicApi/v1/openapi.yml’
at Object.openSync (node:fs:590:3)
at Object.readFileSync (node:fs:458:35)
at Function.Utils.getStringFromFile (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/[email protected]/node_modules/yamljs/lib/Utils.js:284:
the built message
rm: can’t remove ‘/tmp/v8-compile-cache-0/9.4.146.26-node.24/zSusrzSlocalzSlibzSnode_moduleszScorepackzSdistzSpnpm.js.BLOB’: Permission denied
88rm: can’t remove ‘/tmp/v8-compile-cache-0/9.4.146.26-node.24/zSusrzSlocalzSlibzSnode_moduleszScorepackzSdistzSpnpm.js.MAP’: Permission denied
additional information
i had the openapi issue just before i merged the latest changes. commit 5eb0d524591ef699ebd2631b042982170b5055a8
Thanks
i would appreciate any helpful pointer.
i dont rule out that my docker server has an isse or the gitlab runner. becuase the custom image build worked 2 weeks before just fine.
