I am using the n8n Cloud plan and have encountered the following issue across multiple workflows:
- All nodes in the workflow execute smoothly, with the entire workflow completing in under one second.
- However, when I add a Code Node (JavaScript), the workflow times out at the Code Node. This occurs regardless of the complexity of the code or the amount of data being processed. Even minimal code (a few lines) and a small number of items trigger the same behavior.
- If I replace the Code Node with a Set Node using an equivalent inline expression, the workflow performs as expected, even when processing the same data.
The issue does not occur consistently but happens sporadically, making it seem like a resource or compatibility issue on the server side.
Has anyone experienced similar issues or found a solution? Any ideas on how to address this problem?
- **n8n version: 1.72.1
- **Database (default: SQLite): n8n cloud
- **Running n8n via (Docker, npm, n8n cloud, desktop app): n8n cloud
- **Operating system: n8n cloud
