Code Node Runner Timeout Issue
I am experiencing an issue with Code nodes in my n8n Cloud workspace.
All Code nodes fail with the following error:
“Task request timed out after 60 seconds.
Your Code node task was not matched to a runner within the timeout period.”
I have:
Logged out and back in
Cleared executions
Tried duplicating the workflow
Tested with a simple Code node only
The issue persists.
Does this happen with a brand new workflow containing only a single “Code node” that returns a static object?
Hi @RiseOpp_Partnerships Welcome to the community!
Have you tried restarting your cloud instance?
