I found this example: http://community.n8n.io/t/wait-node-in-workflow/73 to add a pause. (Discord doesn’t like it when I try to send multiple items in a short time)
Whenever I try to use the RSS node with it I get an error saying items not defined or not iterable. With no changes it works just fine. Here’s the example using RSS:
"name": "TESTSLEEP",
"nodes": [
"parameters": {},
"name": "Start",
"typeVersion": 1,
"position": [
250,
300
"parameters": {
"functionCode": "const newItems = [];\nfor (const item of items[0].json) {\n newItems.push({json: item});\n}\nreturn newItems;"
"name": "Split up",
"position": [
2310,
3420
"typeVersion": 1
"parameters": {
"url": "https://postman-echo.com/get",
"responseFormat": "string",
"options": {},
"queryParametersUi": {
"parameter": [
"name": "title",
"value": "={{$node[\"Split up\"].data[\"id\"] + \" : \" + Date()}}"
"name": "Send Requests",
"position": [
2798,
3421
"typeVersion": 1
"parameters": {
"functionCode": "const waitTimeSeconds = 3;\n\nreturn new Promise((resolve) => {\n setTimeout(() => {\n resolve(items);\n }, waitTimeSeconds * 1000);\n});\n\n"
"name": "Wait",
"typeVersion": 1,
"position": [
2638,
3421
"parameters": {},
"name": "End",
"type": "n8n-nodes-base.noOp",
"position": [
3188,
3571
"typeVersion": 1
"parameters": {
"batchSize": 1,
"options": {}
"name": "SplitInBatches1",
"type": "n8n-nodes-base.splitInBatches",
"typeVersion": 1,
"position": [
2458,
3421
"parameters": {
"conditions": {
"boolean": [
"value1": true,
"value2": "={{$node[\"SplitInBatches1\"].context[\"noItemsLeft\"]}}"
"name": "IF",
"type": "n8n-nodes-base.if",
"position": [
2988,
3571
"typeVersion": 1
"parameters": {
"url": "https://distrowatch.com/news/dw.xml"
"name": "RSS Feed Read",
"type": "n8n-nodes-base.rssFeedRead",
"typeVersion": 1,
"position": [
2130,
3420
"connections": {
"Split up": {
"main": [
"node": "SplitInBatches1",
"type": "main",
"index": 0
"Send Requests": {
"main": [
"node": "IF",
"type": "main",
"index": 0
"Wait": {
"main": [
"node": "Send Requests",
"type": "main",
"index": 0
"SplitInBatches1": {
"main": [
"node": "Wait",
"type": "main",
"index": 0
