Issue with the n8n Node
Error returning the workflow multiple time, I got a 50 Worfklow but while running the node its returning a 2600+ workflow, its over lopping the node many time
Welcome to the community @AymanJanahi!
It sounds like you probably do not want the node to execute once per item (as it is the default in n8n), but rather once. If that is the case, you should activate “Execute Once” under “Settings”.
