Growing a LinkedIn Company Page usually requires time, consistency, and manual outreach—but with Browserflow + n8n, you can turn the entire process into a hands-off growth engine.
This workflow automates everything from scraping LinkedIn engagement → sending connection invites → tracking acceptance → inviting new connections to follow your company page.
Here’s how to set it up.
Requirements
Before you begin, make sure you have:
A Browserflow account
(7-day free trial available)
A Google Sheet for storing leads
Make a personal copy of my Google Sheets template.
The n8n workflows
I added the template for my workflow as a JSON as a reaction to this post. Please use it for a jumpstart!
Step 1: Retrieve Leads From LinkedIn Posts (Scraping Workflow)
This workflow is shown in the yellow section of your diagram: Retrieve Leads from Post comments.
Its job is simple:
Scrape engaged users from LinkedIn posts
Store them in Google Sheets
Prevent duplicates
1. Add LinkedIn Post URLs
Go to any LinkedIn post → click ••• → Copy link to post → paste into the Posts tab in your Google Sheet.
Choose posts from:
Your competitors
Niche creators
People with highly engaged audiences
2. Connect Browserflow to n8n
Inside n8n:
Open a Browserflow Action
Enter your Browserflow API key
Set your Browserflow flow to scrape:
People who commented
OPTIONAL: People who liked a post
The scraping runs automatically inside the workflow.
What this workflow does
Fetches all posts from Google Sheets
Loops through each post
Calls Browserflow to scrape commenters/likers
Splits the results into individual leads
Filters out invalid or duplicate profiles
Checks if the lead is already in the sheet
- If not, the workflow appends the lead
Marks the post as “scraped” to avoid reprocessing
All of this happens without manual input.
Step 2: Invite Leads as LinkedIn Connections (Outreach Workflow)
Shown in the blue section of your workflow diagram.
This automation handles sending connection invites, checking statuses, and updating your sheet.
A Schedule Trigger starts the workflow (e.g., every 10 minutes).
The workflow fetches leads who haven’t been invited yet.
It loops through each lead.
For every lead, it checks using Browserflow or LinkedIn API:
Is this person already a connection?
Depending on the result:
Not connected → Send LinkedIn invite
Pending → Mark as pending
Already connected → Mark as connected
The Google Sheet updates with the correct status and timestamp.
Optional LinkedIn Premium Invite Message
If you have Premium, you may add a message.
If not—skip it.
LinkedIn gives 3 free invite messages per month, so it’s better to send invites without a note.
Setup steps
After importing the workflow:
Reconnect your Google Sheets credentials
Reconnect your Browserflow or LinkedIn API nodes
Map the appropriate columns from your Google Sheet
Set the schedule interval for sending invites
This workflow will now run continuously until all leads are processed.
Step 3: Update Connection Status (Acceptance Tracking Workflow)
This corresponds to the green section of your diagram.
Its purpose is to track which leads have accepted your invitation.
n8n fetches your most recent LinkedIn connections via Browserflow
The workflow loops over these connections
For each connection, it updates the matching row in Google Sheets
Mark as connected
Add a timestamp
This ensures your sheet is always up to date.
Step 4: Invite Connections to Follow Your Company Page
Shown in the purple section of your diagram.
Once a person accepts your connection invite, another automation takes over:
Fetches your leads from Google Sheets
Looks for leads who:
Are connected
Have not yet been invited to follow your company page
Uses Browserflow to:
Visit your LinkedIn “Connections” page
Invite them to follow your company page
What you must configure:
Enter your Company Page URL into the last action of the workflow.
Make sure you are an Admin of the page
Connect Browserflow with your API key
Map your Google Sheet columns
This workflow will automatically send “Follow Page” invites to new connections.
Final Result: Your Fully-Automated LinkedIn Growth Engine
With Browserflow + n8n working together, you now have:
Automated lead scraping
Target users who engage with posts in your niche.
Automated LinkedIn connection requests
Sent only to new, unprocessed leads.
Automatic acceptance tracking
Your sheet always knows who accepted.
Automated company-page follow invites
Turn every new connection into a company page follower.
Centralized Google Sheets dashboard
Everything is logged, time-stamped, and fully trackable.
This workflow saves hours every week, increases your reach, grows your company page, and ensures consistent LinkedIn activity—with zero manual work.
Please let me know if you need help with the above! Happy Automating​![]()
