Linkedin credential errors
@Jon My linkedin credentials worked, but I can’t publish as an user.
Any update whit this?
Issues:
  • There was a problem loading the parameter options from server: “Forbidden - perhaps check your credentials?”
Hey @Fernanda_Angeloni
Which credential type are you using?
Hi All, a noob here. Is it mandatory to disable
  1. Organization Support
  2. Legacy
    While setting up the LinkedIn Credentials?
    I am self hosting the n8n 1.66.0 app on my VPS. Can I know what have I done wrong?
It give out this when I turn it on:
"### Bummer, something went wrong.
The redirect_uri does not match the registered value"
I rebuild my server and installed n8n again, had some issues with my prior installation. Did the authentication and got the message above.
Hello!
After debugging and conducting many searches, I finally discovered how to make it work.
For me, the issue was a missing “w_organization_social” scope in the app setup on LinkedIn.
I needed to follow these steps: php - LinkedIn API can't add scope and token doesn't have refresh data - Stack Overflow
In the LinkedIn app, I had to request access to the Advertising API and submit the form. After submitting it, my app was able to grant the “w_organization_social” scope.
Finally, I disabled the “Legacy” option and enabled “Support Organization” in N8N.
Thank you. Gotta have a look at that. So you applied for the Marketing thingy yes?
Hello!
No, I just wanted to post via API in an organization page
