Hi everyone
I’m currently exploring ways to identify and collect viral content (scripts, captions, hooks, formats) from TikTok and Instagram, ideally across any niche, to analyze what’s working and why.
I wanted to ask the community:
- Is there any existing n8n workflow that does this?
- Or a reliable approach to scraping TikTok / Instagram without using Apify or expensive paid APIs (especially for someone just starting out)?
What I’m mainly interested in:
- Viral videos or posts
- Captions / scripts / hooks that perform well
- Engagement metrics (views, likes, comments — even partial data is fine)
- A solution that can scale later, but is budget-friendly at the beginning
I understand the platform limitations and TOS concerns, so I’m open to:
- Browser-based scraping approaches
- RSS / third-party data sources
- Creative workarounds using public endpoints or web scraping tools
- Any hybrid solution that plays well with n8n
If you’ve built something similar, seen a workflow, or have ideas on how to approach this efficiently and ethically, I’d really appreciate your insights.
Thanks in advance
Actually Apify has a forever free tier (with $5/mo usage), so I would definitely look into that.
Building custom scrapers that actually keep working for these sites is very hard, so I don’t think there’s a much better solution than trying to look for free tiers - either Apify or similar tools
For something semi-manual you can also look into Chrome extensions such as this one: Instagram Scraper: Export Posts, Reels, Users & more - Chrome Web Store – I doubt these would scale well, but you can get started with it and then later switch to something more scalable.
Use Playwright/Puppeteer to scrape public TikTok/Instagram explore or hashtag pages (cheap, just proxy costs), or a low-cost API like ScraperAPI, ScrapingBee, or PhantomBuster instead of Apify. These handle JS rendering and blocks and are much cheaper for small volumes.
Seconding the Apify free tier suggestion — the $5/month credit goes further than it looks for TikTok/Instagram actors if you run them on a schedule instead of on-demand. Building your own scraper for these platforms is a constant maintenance battle, not worth it for most use cases.
