Loop inside loop: Loop Node does not run over all the items
Describe the problem/error/question: the loop node inside another loop does not ru over all items . It is looping only the first time. starting from the 2nd items it is not looping.
Please share your workflow: {
“nodes”: [
“parameters”: {
“assignments”: {
“assignments”: [
“id”: “9aa7df86-846b-46d9-98c4-8fc5101750b0”,
“name”: “ad_library_url”,
“value”: “={{ $json.ad_library_url }}”,
“type”: “string”
“id”: “cadec2df-0c46-43ea-9943-dbbd00c2da6f”,
“name”: “page_name”,
“value”: “={{ $json.page_name }}”,
“type”: “string”
“id”: “2febee31-7991-4efd-97b4-70f74b8b709a”,
“name”: “display_format”,
“value”: “={{ $json.snapshot.display_format }}”,
“type”: “string”
“id”: “b33dc845-c73c-4136-ba85-a4320121b843”,
“name”: “headline”,
“value”: “={{ $json.snapshot.title }}”,
“type”: “string”
“id”: “20ec68a7-7e38-435a-83e8-de0294cc6f93”,
“name”: “primary_text”,
“value”: “={{ $json.snapshot.body.text }}”,
“type”: “string”
“id”: “d82aec4d-027c-46be-996b-03994100dc64”,
“name”: “link_url”,
“value”: “={{ $json.snapshot.link_url }}”,
“type”: “string”
“id”: “ff13dc6d-a1f3-448b-9165-b2f00da5cbaf”,
“name”: “cards”,
“value”: “={{ $json.snapshot.cards }}”,
“type”: “array”
“id”: “90139302-cb93-4e92-a737-052e54e74db2”,
“name”: “targets_eu”,
“value”: “={{ $json.aaa_info.targets_eu }}”,
“type”: “number”
“id”: “42ff6977-084f-4fdb-9f42-ff3ec7133759”,
“name”: “eu_total_reach”,
“value”: “={{ $json.aaa_info.eu_total_reach }}”,
“type”: “number”
“options”: {}
“type”: “n8n-nodes-base.set”,
“typeVersion”: 3.4,
“position”: [
1744,
3328
“id”: “0d2d55f3-b743-4f48-8f2f-e222264baead”,
“name”: “Carousel Ads: Keeping Fields”
“parameters”: {
“rules”: {
“values”: [
“conditions”: {
“options”: {
“caseSensitive”: true,
“leftValue”: “”,
“typeValidation”: “strict”,
“version”: 2
“conditions”: [
“leftValue”: “={{ $json.video_hd_url }}”,
“rightValue”: “null”,
“operator”: {
“type”: “string”,
“operation”: “notExists”,
“singleValue”: true
“id”: “03cb173b-4378-4cbe-b855-7117b68866c2”
“combinator”: “and”
“renameOutput”: true,
“outputKey”: “Image”
“conditions”: {
“options”: {
“leftValue”: “”,
“version”: 2
“conditions”: [
“id”: “a8ace343-6cc2-4a1a-80bb-0352f32a37d4”,
“leftValue”: “={{ $json.original_image_url }}”,
“operator”: {
“type”: “string”,
“singleValue”: true
“combinator”: “and”
“outputKey”: “Video”
“options”: {}
“type”: “n8n-nodes-base.switch”,
“typeVersion”: 3.3,
“position”: [
2992,
3360
“id”: “78dea684-ec6f-404a-b6f6-7a09e1a08024”,
“name”: “Switch”
“parameters”: {
“options”: {}
“type”: “n8n-nodes-base.splitInBatches”,
“typeVersion”: 3,
“position”: [
1920,
3328
“id”: “4a539347-95c9-4f64-bd9f-0eb850280336”,
“name”: “Loop Over Items”
“parameters”: {
“jsCode”: “// Input shape examples supported:\n// 1) [ { cards: […] } ] // your sample\n// 2) [ { cards: […] }, { … } ] // multiple ads (optional)\n\n// Get the first input item’s JSON\nconst root = items[0]?.json;\n\n// Normalize to an array of “ads”\nconst ads = Array.isArray(root) ? root : [root];\n\n// Flatten cards → one output item per card\nconst out = ;\nads.forEach((ad, adIndex) => {\n const cards = Array.isArray(ad?.cards) ? ad.cards : ;\n cards.forEach((card, cardIndex) => {\n out.push({\n json: {\n adIndex,\n cardIndex,\n totalCards: cards.length,\n …card, // includes body, caption, cta, urls, etc.\n }\n });\n });\n});\n\nreturn out.length ? out : [{ json: { warning: ‘No cards found’ } }];\n”
“typeVersion”: 2,
“position”: [
2384,
3344
“id”: “81fe04ff-9434-477a-8234-7afac83af6bb”,
“name”: “Code for separating the cards”,
“alwaysOutputData”: false
“parameters”: {
“assignments”: {
“assignments”: [
“id”: “bf24b0f9-2e59-4ddf-b043-c8754dab6328”,
“name”: “cards”,
“value”: “={{ $json.cards }}”,
“type”: “array”
“options”: {}
“typeVersion”: 3.4,
“position”: [
2144,
3344
“id”: “f27b43a0-f77c-4b45-a83c-5d35b3cb0219”,
“name”: “Array of Cards”
“parameters”: {
“assignments”: {
“assignments”: [
“id”: “48a2ae58-f424-48dc-91a0-e1c79ac7709f”,
“type”: “string”
“id”: “f63100ed-9c12-43c7-a94e-9642007e1bc9”,
“type”: “string”
“id”: “f06a6a33-2543-451d-909a-b4a653ae9443”,
“value”: “={{ $json.display_format }}”,
“type”: “string”
“id”: “2ee8d2a2-2378-4ce5-acfa-1bce5ab83fdd”,
“name”: “headline”,
“value”: “={{ $json.headline }}”,
“type”: “string”
“id”: “19bc7948-b675-43db-bc13-f4bc3459cfa8”,
“value”: “={{ $json.primary_text }}”,
“type”: “string”
“id”: “89712548-6031-4b9f-81c0-86a0e0944c1e”,
“name”: “link_url”,
“value”: “={{ $json.link_url }}”,
“type”: “string”
“id”: “e21b2d17-bfd7-4bf8-aa82-c459a8529db7”,
“name”: “creative_url”,
“value”: “={{ $json.cards[0].resized_image_url }}”,
“type”: “string”
“id”: “7d559126-ba62-4339-802e-875463251f20”,
“value”: “={{ $json.targets_eu }}”,
“type”: “boolean”
“id”: “83f17cf1-b677-401f-a7cb-be01ff9d49db”,
“value”: “={{ $json.eu_total_reach }}”,
“type”: “number”
“options”: {}
“typeVersion”: 3.4,
“position”: [
1920,
3568
“id”: “baf323b0-10d5-467c-93dc-0e2d472e26d5”,
“name”: “Passing Carousel Ad Data”
“parameters”: {
“url”: “={{ $json.resized_image_url }}”,
“options”: {
“redirect”: {
“redirect”: {
“followRedirects”: false
“typeVersion”: 4.2,
“position”: [
3376,
3120
“id”: “a883bbf2-023c-4964-bd0e-663d63b344fc”,
“name”: “HTTP Request2”,
“alwaysOutputData”: true,
“onError”: “continueErrorOutput”
“parameters”: {
“promptType”: “define”,
“text”: “You are a senior advertising creative analyst. You will receive an image with this prompt. Analyze it thoroughly.\n\nTask:\nWhat’s in this image? Analyze it extremely comprehensively.\n\nReturn ONLY a valid JSON object (no prose, no markdown, no backticks) with this exact schema and keys:\n\n{\n “visual_analysis”: “”,\n “hook_elements”: ,\n “main_offer”: “”,\n “psychological_triggers”: \n}\n\nInstructions:\n- Base everything strictly on what is visible in the image. Do not guess. If a field is not clearly present, use “” or .\n\n- visual_analysis: begin with a concise factual inventory of all visible elements (people/objects, product renders, logos, badges, UI, background, colors, lighting, and all on-image text verbatim). Then analyze how those elements work together:\n • Focal points & visual hierarchy (what captures attention first, second, third)\n • Composition & layout (placement/safe zones, spacing, balance, crops)\n • Color/contrast strategy and readability\n • Information flow and message framing (benefit, proof, urgency, social proof, etc.)\n • Brand cues (logos, typography, device/product presentation)\n • Likely effect on attention/comprehension and fit for placement (e.g., feed/story/mobile)\n Keep the analysis grounded in visible evidence.\n\n- hook_elements: up to 3 short hooks the creative uses or implies; use exact on-image wording when applicable.\n\n- main_offer: the core value proposition or offer exactly as written on the image; if none, return “”.\n\n- psychological_triggers: 3 triggers supported by the visuals only (e.g., novelty, authority, scarcity, social proof, convenience, time saving, FOMO).\n\nFormatting rules:\n- Output must be valid JSON. No extra keys. No trailing commas.\n- Escape quotes inside strings. Keep arrays as flat strings.\n- Do not include any explanatory text outside the JSON.\n\nIf the image cannot be accessed or read, return the same JSON with empty values.\n”,
“hasOutputParser”: true,
“options”: {}
“type”: “@n8n/n8n-nodes-langchain.agent”,
“typeVersion”: 2.2,
“position”: [
4048,
3104
“id”: “5c785fb2-16e3-4994-adf6-ad5d13cb6d28”,
“name”: “AI Agent2”,
“retryOnFail”: true,
“onError”: “continueRegularOutput”
“parameters”: {
“model”: {
“__rl”: true,
“mode”: “list”,
“value”: “gpt-4.1-mini”
“options”: {}
“type”: “@n8n/n8n-nodes-langchain.lmChatOpenAi”,
“typeVersion”: 1.2,
“position”: [
4048,
3264
“id”: “531eb52d-282e-4a8b-a47d-fea90846ea8c”,
“name”: “OpenAI Chat Model2”,
“credentials”: {
“openAiApi”: {
“id”: “joTQ0lGTKum2MhtD”,
“name”: “OpenAi Ads Formula Valid”
“parameters”: {
“jsonSchemaExample”: “{\n “visual_analysis”: “string (1–1200 chars)”,\n “hook_elements”: [“string (1–80 chars)”],\n “main_offer”: “string (0–160 chars)”,\n “psychological_triggers”: [“string (1–60 chars)”]\n}”
“type”: “@n8n/n8n-nodes-langchain.outputParserStructured”,
“typeVersion”: 1.3,
“position”: [
4192,
3264
“id”: “cc467362-b4f0-4c8b-bd26-8e90c7f434ee”,
“name”: “Structured Output Parser2”
“parameters”: {
“amount”: 1
“id”: “9ae43f07-7d44-4da1-ab3e-75b6b0f3d40f”,
“name”: “Wait 1 sec2”,
“type”: “n8n-nodes-base.wait”,
“position”: [
5504,
3872
“webhookId”: “1cda7407-6321-4d8d-b532-19f42514eb63”,
“typeVersion”: 1.1
“parameters”: {
“mode”: “combine”,
“combineBy”: “combineAll”,
“options”: {}
“type”: “n8n-nodes-base.merge”,
“typeVersion”: 3.2,
“position”: [
4448,
3296
“id”: “64a64969-e7ab-4de3-bb23-3805a5260a9b”,
“name”: “Merge Image Ad Details2”
“parameters”: {
“assignments”: {
“assignments”: [
“id”: “11558f4e-7ab1-40d3-92f2-ed27e0f0d601”,
“name”: “adIndex”,
“value”: “={{ $json.adIndex }}”,
“type”: “number”
“id”: “6708d2d4-c98c-4ade-8266-b6cc74028894”,
“name”: “cardIndex”,
“value”: “={{ $json.cardIndex }}”,
“type”: “number”
“id”: “8f5cd132-6e40-4fe5-87ea-5edd7b0fd577”,
“name”: “body”,
“value”: “={{ $json.body }}”,
“type”: “string”
“id”: “3e68696c-99eb-4fa0-a8e6-1927b824ed60”,
“name”: “title”,
“value”: “={{ $json.title }}”,
“type”: “string”
“id”: “c070d84f-abe7-4c24-85cb-983184730f87”,
“name”: “link_url”,
“type”: “string”
“id”: “f17549fd-b36c-473e-8196-005b0671905d”,
“name”: “resized_image_url”,
“value”: “={{ $json.resized_image_url }}”,
“type”: “string”
“options”: {}
“typeVersion”: 3.4,
“position”: [
3376,
3312
“id”: “f3240cc9-c2a7-4060-8060-9851223d0d20”,
“name”: “Passing Image Card Data”
“parameters”: {
“operation”: “append”,
“documentId”: {
“__rl”: true,
“value”: “1AS2gzcXg2Gp5d4yNCpQcWulKrGq3BWJGKS5eUHB-FTw”,
“mode”: “list”,
“cachedResultName”: “Ads_Library_Analyzer”,
“cachedResultUrl”: “https://docs.google.com/spreadsheets/d/1AS2gzcXg2Gp5d4yNCpQcWulKrGq3BWJGKS5eUHB-FTw/edit?usp=drivesdk”
“sheetName”: {
“__rl”: true,
“value”: 1561928389,
“mode”: “list”,
“cachedResultName”: “Carousel Cards”,
“cachedResultUrl”: “https://docs.google.com/spreadsheets/d/1AS2gzcXg2Gp5d4yNCpQcWulKrGq3BWJGKS5eUHB-FTw/edit#gid=1561928389”
“columns”: {
“mappingMode”: “defineBelow”,
“value”: {
“hook_elements”: “={{ $json.output.hook_elements }}”,
“main_offer”: “={{ $json.output.main_offer }}”,
“psychological_triggers”: “={{ $json.output.psychological_triggers }}”,
“visual_analysis”: “={{ $json.output.visual_analysis }}”,
“adindex”: “={{ $json.adIndex }}”,
“cardindex”: “={{ $json.cardIndex }}”,
“body”: “={{ $json.body }}”,
“title”: “={{ $json.title }}”,
“link_url”: “={{ $json.link_url }}”,
“creative_url”: “={{ $json.resized_image_url }}”
“matchingColumns”: ,
“schema”: [
“id”: “adindex”,
“displayName”: “adindex”,
“required”: false,
“defaultMatch”: false,
“display”: true,
“type”: “string”,
“canBeUsedToMatch”: true,
“removed”: false
“id”: “cardindex”,
“displayName”: “cardindex”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “body”,
“displayName”: “body”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “title”,
“displayName”: “title”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “link_url”,
“displayName”: “link_url”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “creative_url”,
“displayName”: “creative_url”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “visual_analysis”,
“displayName”: “visual_analysis”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “hook_elements”,
“displayName”: “hook_elements”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “main_offer”,
“displayName”: “main_offer”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “psychological_triggers”,
“displayName”: “psychological_triggers”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“attemptToConvertTypes”: false,
“convertFieldsToString”: false
“options”: {}
“id”: “437bb0ab-11b2-4fbd-be66-88bc3147ceec”,
“name”: “Adding Cards Data”,
“type”: “n8n-nodes-base.googleSheets”,
“position”: [
5456,
3296
“typeVersion”: 4.6,
“credentials”: {
“googleSheetsOAuth2Api”: {
“id”: “Gp6tqzdRRxGutUxf”,
“name”: “Ads Formula”
“parameters”: {
“documentId”: {
“__rl”: true,
“mode”: “list”,
“sheetName”: {
“__rl”: true,
“value”: “gid=0”,
“mode”: “list”,
“cachedResultName”: “Visual Analysis”,
“cachedResultUrl”: “https://docs.google.com/spreadsheets/d/1AS2gzcXg2Gp5d4yNCpQcWulKrGq3BWJGKS5eUHB-FTw/edit#gid=0”
“columns”: {
“value”: {
“primary_text”: "={{ $json.primary_text }} ",
“headline”: “={{ $json.headline }}”,
“ad_library_url”: “={{ $json.ad_library_url }}”,
“page_name”: “={{ $json.page_name }}”,
“display_format”: “={{ $json.display_format }}”,
“creative_url”: “={{ $json.creative_url }}”,
“target_eu”: “={{ $json.targets_eu }}”,
“eu_total_reach”: “={{ $json.eu_total_reach }}”
“schema”: [
“id”: “ad_library_url”,
“displayName”: “ad_library_url”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “page_name”,
“displayName”: “page_name”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “display_format”,
“displayName”: “display_format”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “headline”,
“displayName”: “headline”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “primary_text”,
“displayName”: “primary_text”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “link_url”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “target_eu”,
“displayName”: “target_eu”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“id”: “eu_total_reach”,
“displayName”: “eu_total_reach”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: false
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“id”: “main_offer”,
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“required”: false,
“display”: true,
“type”: “string”,
“removed”: true
“options”: {}
“id”: “3771a266-9ba5-4268-b652-2d303f56fcd6”,
“name”: “Adding Carousel Ad Data”,
“position”: [
1920,
3808
“typeVersion”: 4.6,
“credentials”: {
“parameters”: {
“options”: {}
“typeVersion”: 3,
“position”: [
2592,
3344
“id”: “5320e87c-5a45-4e25-a0e9-36bb9d193830”,
“name”: “Loop Over Items1”
“connections”: {
“Carousel Ads: Keeping Fields”: {
“main”: [
“node”: “Loop Over Items”,
“type”: “main”,
“index”: 0
“Switch”: {
“main”: [
“node”: “HTTP Request2”,
“type”: “main”,
“index”: 0
“node”: “Passing Image Card Data”,
“type”: “main”,
“index”: 0
“Loop Over Items”: {
“main”: [
“node”: “Array of Cards”,
“type”: “main”,
“index”: 0
“node”: “Passing Carousel Ad Data”,
“type”: “main”,
“index”: 0
“Code for separating the cards”: {
“main”: [
“node”: “Loop Over Items1”,
“type”: “main”,
“index”: 0
“Array of Cards”: {
“main”: [
“node”: “Code for separating the cards”,
“type”: “main”,
“index”: 0
“Passing Carousel Ad Data”: {
“main”: [
“node”: “Adding Carousel Ad Data”,
“type”: “main”,
“index”: 0
“HTTP Request2”: {
“main”: [
“node”: “AI Agent2”,
“type”: “main”,
“index”: 0
“type”: “main”,
“index”: 0
“AI Agent2”: {
“main”: [
“node”: “Merge Image Ad Details2”,
“type”: “main”,
“index”: 0
“OpenAI Chat Model2”: {
“ai_languageModel”: [
“type”: “ai_languageModel”,
“index”: 0
“Structured Output Parser2”: {
“ai_outputParser”: [
“type”: “ai_outputParser”,
“index”: 0
“Wait 1 sec2”: {
“main”: [
“type”: “main”,
“index”: 0
“Merge Image Ad Details2”: {
“main”: [
“node”: “Adding Cards Data”,
“type”: “main”,
“index”: 0
“Passing Image Card Data”: {
“main”: [
“type”: “main”,
“index”: 1
“Adding Cards Data”: {
“main”: [
“node”: “Wait 1 sec2”,
“type”: “main”,
“index”: 0
“Adding Carousel Ad Data”: {
“main”: [
“Loop Over Items1”: {
“main”: [
“type”: “main”,
“index”: 0
“node”: “Switch”,
“type”: “main”,
“index”: 0
“pinData”: {},
“meta”: {
“instanceId”: “b4f80ba632bad682ebf8b1da401c7d3ce313277133387e4543f367f78a1da6b0”
i have same issue some one can help us ?
Hi @mredodos , kindly check this question, the solution suggested by mohamed3nan worked for me : Second nested Loop Over Items does not restart in each iteration of the outer loop
