The idea is:
The only reason to have a manual trigger is to run an automation from the UI. So when the manual trigger is present and active, the automation should -ALWAYS- start from the manual trigger. Any other behavior is counterintuitive.
If someone wants to test whether their webhook-initiated flow is working right, they should not have a manual trigger present. Then their flow will either used the pinned data in the webhook trigger or wait for a test request.
My use case:
In this flow, there’s a postgres query attached to the manual trigger to reset the flags on the records that will be processed. But as you can see in this screenshot, when I click “test workflow” it starts from the schedule trigger instead of the manual trigger. That is definitely not what I would expect.
Debugging is hard enough without having to wrestle with the debugger!
This behavior isn’t documented.
Nobody wants that. ![]()
P.S. Happy Halloween - I like the cobwebs!
