Maximum number of redirects exceeded
Hello, I have a very simple workflow that normally connects to Grist to retrieve data from a spreadsheet. My workflow was working normally, but since yesterday I've been encountering the error.
"Problem in node ‘HTTP Request‘ Maximum number of redirects exceeded"
I verified my credentials directly on the Grist console API and my requests are working. I renewed the API, but I'm still getting error 302.
Hello @vincent_LINUXiste,
are you enabling the option “Redirects” in the HTTP node?!
It would also be helpful if you could share a screenshot of the error or a sample workflow to reproduce it, along with your n8n instance information, etc..
