When trying to run a flow using split in batches, alway reveive this message:
The date to process is very small, only three rows on a google sheet spreadsheet that I need to process one by one.
- n8n version: 0.234.0
- Database (default: SQLite): SQLite
- Operating system: Synology NAS DSM
Hi @MaaPer
Does the workflow only have the two nodes you’re showing, or are you showing a smaller workflow for the issue? Also, can you confirm how much data is being handled? I know you mentioned three rows, but how much data is in them?
Can you also share your Docker logs so we can see any errors in more detail?
Hi, many thanks for your reply.
The sheet has only three rows and about 14 columns so its a very small dataset.
I only share part of the flow but there is only one node left that is an HTTP request to an API of my invoicing program.
The storage thing is that now its working without error….
Odd that it’s working now without issues, but I’m glad it is! If this happens again, feel free to share those Docker logs so we can take a closer look
