Merge Node Not Combining Data Correctly from Two Branches
Hi everyone, I’m having an issue with the Merge node in n8n. I’m trying to combine data from two different branches, but the output is not what I expect.
My workflow looks like this:
HTTP Request (Users) → Merge ← HTTP Request (Orders)
The first HTTP node returns user data, and the second returns order data. I’m trying to merge them so each user has their related order info, but instead I either get:
• Only data from one side
• Or mismatched items (wrong user with wrong order)
{ “user_id”: 1, “product”: “Shoes” },
{ “user_id”: 2, “product”: “Bag” }
In the Merge node, I tried using “Merge by Index”, but I think that might be wrong. I also tried “Combine”, but the structure still doesn’t match what I expect.
Hi @Keira_Becky
The issue is the Merge mode you’re using.
Merge by Index just matches items by position (0 with 0, 1 with 1), not by actual data. So if the order changes, you’ll get wrong matches.
You should use Merge by Key instead:
• Input 1 (Users): id
• Input 2 (Orders): user_id
This matches records correctly like this
user.id === order.user_id
Also make sure both fields are the same type I mean both numbers
Hi @Keira_Becky Are you using merge node combined? which is set to user_id as the matching field for both incoming inputs?
