Merge node remove key match not work
I’m trying to build a sync system between Dolibarr and woocommerce with Merge node remove key match but not work, My two inputs seems similare on the output view but merge node give me the object that already match.
Please share the workflow
    "id": 49326,
    "name": "Coffret Neige  parfum, musc tahara, citadelle, chap. Amma.",
    "slug": "coffret-neige-parfum-musc-tahara-citadelle-chap-amma"
    "id": 49323,
    "name": "Coffret gris (Tapis, parfum, chapelet)",
    "slug": "coffret-gris-tapis-parfum-chapelet"
  • n8n version:0.160.0
  • Database you’re using (default: SQLite):slight_smile:
  • Running n8n with the execution process [own(default), main]:
  • **Running n8n via Windows **
Welcome to the community @amysticool!
It looks like the Merge Node is not configured correctly. The Parameters “Property Input X” expect the name of the fields, not the value. Here and example how it should look like:
If that gets adjusted, it works correctly.
Here is your corrected example workflow:
Thanks for your reply
