Merging Split in Batches data
I know this get’s asked a lot, I promise I searched!!
I’m trying to merge data from a split in batches node - within the loop I have the data formatted correctly. The final output is messing me up.
I tried the method with this workflow but it’s giving me this:
When I’m trying to get this:
Any help is greatly appreciated!!
Please share the workflow
  • Database you’re using (default: SQLite):
  • Running n8n with the execution process [own(default), main]:
  • Running n8n via [Docker, npm, n8n.cloud, desktop app]:
Hi @Tzvi_S, you could either use an Item Lists node at the end of your workflow to split out the “allData” field or use this template instead:
It would return individual items instead of a single item with an “allData” field like so:
Let me know if you run into any trouble with this :slight_smile:
