Milvus database node settings
The idea is:
The first missing setting on this node is “metric_type”, actually, it’s locked to L2, however Zilliz (their creator and hoster) mostly use Cosine.
Would be great to have the metric_type as an option to have the option to choose between L2 and Cosine.
My use case:
I cannot save any vector to a Milvus database hosted by Zilliz while they use a different metric_type
If you wish to be compatible with the creators of Milvus (Zilliz)
With pleasure, it’s easy to fix
