Missing "Base URL" Setting in OpenRouter Chat Model Node
Hi,
Thanks for adding the OpenRouter Chat Model node.
I couldn’t find the “Base URL” setting mentioned in the documentation. It’s not available in the node itself or in the OpenRouter credentials. This setting could be useful, for example, when using OpenRouter with Helicone.
  • n8n version: 1.77.3
  • Running n8n via n8n cloud
Is there a way to set it up?
Thanks.
I am also facing this issue
Just ran into this problem too.
Base URL is missing from OpenRouter and an option to add custom headers (also missing from the OpenAI node). Helicone-Auth Header is needed in the requests.
same issue here
Same issue here
Just to clear this up, this isn’t a bug it just isn’t implemented. Is there a reason why OpenRouter would need a base url?
Most services implement the OpenAI spec and the OpenAI node does have the url option available.
