Mobility and Data transformation shortcuts
The idea is:
To add a few shortcuts to move between nodes using the keyboard or pinning the data just pressing a key.
My use case:
Having to manually revise node per node for data pinning in extensive workflows
It could improve the user experience and the ease in which workflows are worked
Honestly, I see it as a great opportunity to improve, since working with a keyboard is generally more comfortable.
