Hi, can you help me with this node ?
My source are some pase64 pdf that are coming like this:
1.
2.
But the Pase64 content would be not processed.
What can i do ?
Thanks,
Stefan
1.
What can i do ?
Thanks,
Stefan
I have it. Another question: How i can have the right file-name from the pdfs ? When i use file-name from the before node its every the first one.
Thanks,
Stefan
Great that you could figure out the first part.
About the second one. More or less impossible to help you there. Could you share a workflow which demonstrates that problem (with some mock data) that we can debug and post back a solution?
Yes, I know now what you mean. I checked the code and there was was a bug in the code, sorry! It read the “Options” wrong. The bug got fixed now:
https://github.com/n8n-io/n8n/commit/729da6f73ee0ae6ab753e8c35d0c5c4fde257167
It will be released with the next version. I will inform you here once it got released.
