Just confirming that it’s NOT possible to execute a multi-statement SQL query in a single Snowflake node?
I see in the Snowflake REST API docs that you can specify the number of statements in a request but don’t see that as a feature/option on the node.
Can anyone confirm if this is or isn’t possible in n8n currently?
Much appreciated!
ERROR: Actual statement count 11 did not match the desired statement count 1.
n8n version: 1.0.5
Database (default: SQLite): PostgreSQL
Running n8n via (Docker, npm, n8n cloud, desktop app): Docker
Operating system: MacOS Ventura 13.5
Hi @Keith_Khazae
Welcome to the community
Can you provide an example of the multi-statement query you were trying to run? Obviously don’t include any sensitive data
@EmeraldHerald Thank you for your reply, sorry for the delay. See code below.
SET DOMAINS = 3;
SET DAY1LISTSIZE = 100;
CREATE OR REPLACE TEMPORARY TABLE REV_SENDING AS
SELECT
ROW_NUMBER() OVER (PARTITION BY 1 ORDER BY ListBreaks ASC) AS RW
FROM (
SELECT email AS EMAILADDRESS
,sum(score) score
,id as recipientId
,dense_rank() OVER (PARTITION BY CASE
WHEN lower(EMAILADDRESS) LIKE ('%@gmail%') then 1
WHEN lower(EMAILADDRESS) LIKE ('%@yahoo%') then 2
WHEN lower(EMAILADDRESS) LIKE ('%@hotmail%') then 3
WHEN lower(EMAILADDRESS) LIKE ('%@aol%') then 4
ELSE 5 END
ORDER BY sum(score) desc
) ListBreaks
FROM (
select a.email
,b.message_id
,div0(1,(current_date - max(cast(b.created_at as date)))) as score
,a.id
from TABLE1 a
left join TABLE2 b
on trim(lower(a.email))=trim(lower(b.email))
left join TABLE3 c
on trim(lower(a.email))=trim(lower(c.email))
left join TABLE4 d
on trim(lower(a.email))=trim(lower(d.email))
left join TABLE5 e
on trim(lower(a.email))=trim(lower(e.email))
left join TABLE6 f
on trim(lower(a.id))=trim(lower(f.recipient_id))
where
c.email is null
and d.email is null
and e.email is null
and f.recipient_id is null
group by
a.email,
b.message_id,
a.id
where
score is not null
and email not like '%+%'
group by
email,
id
) a
ALTER TABLE REV_SENDING CLUSTER BY (RW);
SET FULLLIST = (SELECT COUNT(DISTINCT EMAILADDRESS) FROM REV_SENDING);
SET WARMUPDAYS = (SELECT ROUND(((LN(COUNT(DISTINCT EMAILADDRESS)) - LN($DAY1LISTSIZE * $DOMAINS))/LN(2)) + 0.5) FROM REV_SENDING);
SET LISTS = (SELECT $WarmupDays * $Domains);
CREATE OR REPLACE PROCEDURE CreateDynamicRowsTable(NUM_ROWS INT)
RETURNS STRING
LANGUAGE SQL
EXECUTE AS CALLER
AS
BEGIN
CREATE OR REPLACE TEMPORARY TABLE DynamicRowsTable AS
SELECT
ROW_NUMBER() OVER (ORDER BY 1) AS Day,
'Data for row ' || ROW_NUMBER() OVER (ORDER BY 1) AS Data
FROM TABLE(GENERATOR(ROWCOUNT => :NUM_ROWS));
RETURN 'DynamicRowsTable created with ' || NUM_ROWS || ' rows.';
END;
CALL CreateDynamicRowsTable($WARMUPDAYS);
CREATE OR REPLACE TEMPORARY TABLE REV_SENDING_FULL AS
SELECT a.*, b.DAY
FROM REV_SENDING a
LEFT JOIN DynamicRowsTable b on 1 = 1;
SELECT EMAILADDRESS, DAY, NTILE($DOMAINS) OVER (PARTITION BY DAY ORDER BY RW_DOMAIN) DOMAIN, SCORE
FROM (
SELECT EMAILADDRESS, DAY, ListBreaks, ROW_NUMBER() OVER (PARTITION BY DAY, LISTBREAKS ORDER BY RANDOM()) RW_DOMAIN, SCORE
FROM (
SELECT EMAILADDRESS, MIN(DAY_FINAL) DAY, SCORE, ListBreaks
from (
SELECT *, CASE WHEN RW <= $DOMAINS * $DAY1LISTSIZE THEN 0 ELSE DAY END AS DAY_FINAL
FROM
REV_SENDING_FULL
) a
WHERE RW <= $DOMAINS * $DAY1LISTSIZE * POW(2,DAY)
GROUP BY EMAILADDRESS, LISTBREAKS, SCORE
) b
) c
ORDER BY DAY asc, DOMAIN asc;
Thanks for that @Keith_Khazae
With a little bit more digging it does indeed look like this isn’t supported at the moment on the Snowflake node. I’ve moved this over to the feature request section of our forum so our product team can get eyes on it, and others can upvote
