My ClickUp Task Comment Posted workflow trigger node is triggering twice for some reason
On the ClickUp trigger node for when a new task comment is posted, it appears to be triggering twice whenever a new comment is posted to a task, instead of once.
No error message, but the workflow runs twice at exactly the same time or with a couple of seconds difference. See screenshot of the execution happening twice:
I’m not a software developer, but used ChatGPT to guide me through how to list webhooks for my ClickUp account and I can only see one for taskcommentposted. It is the correct webhook url (the one shown in the clickup trigger node configuration). There’s isn’t a second one, so I don’t know why its triggering twice.
Redacted some info.
“nodes”: [
“parameters”: {
“team”: “[Redacted]”,
“events”: [
“taskCommentPosted”
“filters”: {}
“type”: “n8n-nodes-base.clickUpTrigger”,
“typeVersion”: 1,
“position”: [
-200,
0
“id”: “d233902b-b0c5-410a-b2c6-8140bd73abe9”,
“name”: “On Task Comment”,
“webhookId”: “cd55778a-f9a8-4232-a17c-f75bc5fa4af8”,
“credentials”: {
“clickUpApi”: {
“id”: “mPlFSL0axsWEiREd”,
“name”: “[Redacted]”
“connections”: {
“On Task Comment”: {
“main”: [
“pinData”: {},
“meta”: {
“instanceId”: “a537cd01082cdf8c84ee7a40239091dc3d61153f66f347ff9fa5cc4dc5444655”
  • n8n version 1.101.2:
  • Running n8n via Railway self-hosted deployment:
  • Operating system: MacOS
Dear JinaniLXd,
I have try creating the same workflow as you are facing the issue with. And as you can see in the image my workflow is performing perfectly and it also triggering only the one time.
But after some bug digging, I have figure out the problem.
The issue is persistining because of following response.
  • The automation inside clickup you have setup to trigger the webhook, is not setup properly.
Or may be setup two types, as you are receiving the comment information from Clickup two times.
So, as per my knowledge the issue may be is not with n8n, but it’s with how you have set up the automation inside Clickup to trigger this workflow.
Once you arrnage the clickup automation inside the platform, I think the problem gonna be solve.
Happy to help dear.
(If this answer solve your query, please mark it as answer, because this will help me help other with the same problems)
