N8n course level 2, discord problem
Hello all,
I have finished my level 2 quiz and also the workflows execution. However, after my discord node execution, I keep getting message “Your messgae is incorrectly formatted.” Can someone please guide me? I also tried removing the outer double quotes, still I get the same message. It’s just the formatting problems
Welcome to the n8n community @deshmukhsanket
Your message should follow this pattern exactly
I sent the file using email with the label ID {{ $json.id }}. My ID: YOUR_UNIQUE_ID_HERE
PS; Ensure you’re using the Level 2 course webhook URL from your email, not the Level 1 one
Hi @deshmukhsanket remove the " " from the message you are sending.
Hey all,
thanks, I was using the course 1 webhook URL. Just changed it and verified using this link n8n Level 2 Course Verification
It shows verified now, but I did not receive any email from n8n about completion, do I have to take the entire quiz again?
try without any quotes around the message — sometimes discord is picky about the formatting. if youre using a json node before the discord node, check the actual output first
Glad to help @deshmukhsanket
Edit: No, you need not retake the entire quiz.
just to corret, we do not need to retake entire quiz. My status has been updated under my profile automatically
