N8n - JSON to JSONL batch processing (code node is stuck in "executing"
Two problems
  1. I am trying to use the code node, and javascript > however as soon as it gets input it goes in “executing node…” and gets stuck there.
  2. I simply want to convert array of json data into jsonl file (I know using code node + create binary file is the right way to do this, but as I mentioned code node isn’t working for me. is there any otherway to do this?)
Could you provide your workflow json within the code backticks (click the </> button)?
Could you provide your current code in the relevant code nodes?
