N8n Level 2 Course Discord Node Error Issue
Discord node showing error:- “{
“errorMessage”: " [item 0]“,
“errorDetails”: {},
“n8nDetails”: {
“nodeName”: “Discord2”,
“nodeType”: “n8n-nodes-base.discord”,
“nodeVersion”: 2,
“operation”: “sendLegacy”,
“itemIndex”: 0,
“time”: “10/9/2025, 8:13:04 AM”,
“n8nVersion”: “1.115.1 (Self Hosted)”,
“binaryDataMode”: “default”,
“stackTrace”: [
“NodeOperationError: “,
" at ExecuteContext.parseDiscordError (C:\Users\Nyk\AppData\Roaming\npm\node_modules\n8n\node_modules\n8n-nodes-base\nodes\Discord\v2\helpers\utils.ts:84:9)”,
" at ExecuteContext.execute (C:\Users\Nyk\AppData\Roaming\npm\node_modules\n8n\node_modules\n8n-nodes-base\nodes\Discord\v2\actions\webhook\sendLegacy.operation.ts:153:34)”,
" at processTicksAndRejections (node:internal/process/task_queues:105:5)”,
" at ExecuteContext.router (C:\Users\Nyk\AppData\Roaming\npm\node_modules\n8n\node_modules\n8n-nodes-base\nodes\Discord\v2\actions\router.ts:70:17)“,
" at ExecuteContext.execute (C:\Users\Nyk\AppData\Roaming\npm\node_modules\n8n\node_modules\n8n-nodes-base\nodes\Discord\v2\DiscordV2.node.ts:33:10)”,
" at WorkflowExecute.executeNode (C:\Users\Nyk\AppData\Roaming\npm\node_modules\n8n\node_modules\n8n-core\src\execution-engine\workflow-execute.ts:1093:8)“,
" at WorkflowExecute.runNode (C:\Users\Nyk\AppData\Roaming\npm\node_modules\n8n\node_modules\n8n-core\src\execution-engine\workflow-execute.ts:1274:11)”,
" at C:\Users\Nyk\AppData\Roaming\npm\node_modules\n8n\node_modules\n8n-core\src\execution-engine\workflow-execute.ts:1676:27",
" at C:\Users\Nyk\AppData\Roaming\npm\node_modules\n8n\node_modules\n8n-core\src\execution-engine\workflow-execute.ts:2292:11"
I have already updated n8n. But it didn’t solve the problem . Can anyone help me out.
I’m having the same problem
“errorDetails”: {},
“n8nDetails”: {
“nodeName”: “Discord”,
“nodeVersion”: 2,
“itemIndex”: 0,
“time”: “10/21/2025, 4:21:40 PM”,
“n8nVersion”: “1.116.2 (Cloud)”,
“stackTrace”: [
" at ExecuteContext.parseDiscordError (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@aws-sdk+credential-providers@3.808.0_asn1.js@5_afd197edb2c1f848eae21a96a97fab23/node_modules/n8n-nodes-base/nodes/Discord/v2/helpers/utils.ts:84:9)”,
" at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@aws-sdk+credential-providers@3.808.0_asn1.js@5_afd197edb2c1f848eae21a96a97fab23/node_modules/n8n-nodes-base/nodes/Discord/v2/actions/webhook/sendLegacy.operation.ts:153:34)”,
" at ExecuteContext.router (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@aws-sdk+credential-providers@3.808.0_asn1.js@5_afd197edb2c1f848eae21a96a97fab23/node_modules/n8n-nodes-base/nodes/Discord/v2/actions/router.ts:70:17)“,
" at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@aws-sdk+credential-providers@3.808.0_asn1.js@5_afd197edb2c1f848eae21a96a97fab23/node_modules/n8n-nodes-base/nodes/Discord/v2/DiscordV2.node.ts:33:10)”,
" at WorkflowExecute.executeNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1093:8)“,
" at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1274:11)”,
" at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1699:27",
" at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:2315:11"
Hello @Ram_Chauhan ,
I had the same issue. But I remark that I was using the same credential of the courses level 1. You should signed again and use the new credentials received by email . Course Level 2 Sign-up
