Hey @Faha, I am very sorry to hear you’re having trouble. This isn’t a node provided by n8n I am afraid and as such I am not very familiar with it. Your best bet is to wait for a response from the maintainer on GitHub here.
Hey @Faha
I was having the same issue getting n8n-nodes-puppeteer to work inside docker. I created the github repo n8n-puppeteer-docker to build and run a docker image.
Hey @marcus this discussion was so long ago, I don’t know if you will see this. But I am a noobie when it comes to coding, so I appreciate your patience. I am trying to host my n8n instance on Railway. I used the n8n template they provide which made it super simple to launch.
I am now trying to figure out how to integrate puppeteer into this setup, and I am a little stuck. I can add a docker image to this current setup, but I don’t know how that would work if Railway already has it’s own docker image? Sorry, I don’t understand it all. Any guidance is super appreciated. I have been sending HTTP calls from N8n to Appify for a Loooooong time for some pretty simple Puppeteer scripts, so getting this in a n8n node form would be a life saver.
