N8n on WLS2 data return issues
hi I’m evaluating this for potential use within my company. I’ve set it up to run on my local (WLS 2 windows 10) and trying out type form integration using access token and I can see the name of the form I have created in type form. However i can not see the data that has been collected via this form. is there a step I have missed?
Welcome to the community @Pa_A!
Did you follow our quick guide, it even specifically uses TypeForm?
There is also a video you can follow.
