Native Data Mapper node: map data into a target structure without code
The idea is:
A core Data Mapper node that maps incoming data into a defined target structure (JSON, XML or CSV) without writing code.
You give the node the shape of the output, and it lists every target field for you to fill:
  • Target structure from a sample: paste a sample JSON or XML, a JSON Schema, an XSD or a CSV header.
  • Source for each field: pick it from a dropdown, drag it from the input panel, or use an expression or fixed text.
  • Repeating data: map lists in the source (order lines, addresses) to lists in the target, including nested lists, with no Split Out, Loop or Aggregate nodes.
  • Auto-map by name: match fields automatically, including common abbreviations (Qty → quantity, OrderNo → orderNumber), with a report of what matched and what didn’t.
  • Transforms per field: convert to number or boolean, format dates, trim and change case, look up values in a table, split and join lists, and concatenate fields with text.
  • Output: JSON, XML (fields in schema order, with attributes) or CSV, as an item or a file.
  • Reusable mappings: save a mapping as a JSON definition and reuse it across workflows.
My use case:
Integration workflows that move orders, products and invoices between shops, marketplaces, ERPs and carriers. Each system expects its own structure, often XML or CSV with nested repeating sections.
Example: a shop order with several line items has to become an ERP order XML with a header and repeating <line> elements. Today in n8n that needs one of:
  • Edit Fields (Set): fine for flat fields, but it has no target schema and can’t map nested lists into the target on its own.
  • A Split Out → Edit Fields → Aggregate chain: works, but it’s hard to read and breaks when the structure changes.
  • A Code node: flexible, but it needs JavaScript.
A mapping that takes one node in other integration platforms often takes 5–10 nodes or a script in n8n.
  • No-code and low-code users get stuck here. Mapping between data structures is the most common integration task, and it’s where non-developers need someone who writes code.
  • It can only reach n8n Cloud as a core node. I published this as the community node n8n-nodes-data-mapper (MIT). n8n confirmed that logic nodes can’t be verified, because verification only covers integrations with third-party services. Unverified community nodes can’t be installed on n8n Cloud.
  • Workflows are easier to maintain. One node with a visible field-by-field mapping is easier to review, debug and hand over than a chain of nodes or a script.
  • It builds on what n8n already has. The field-mapping widget and drag-and-drop from the input panel already exist, so this adds no new concept for users to learn.
  • There is real demand. The community node has been downloaded [+500] times without being in the verified catalog.
Yes. I’m happy to share the existing implementation, test cases and lessons learned, or to contribute to a core version if the n8n team is open to it.
If this would help you too, please upvote this request.
