Need help connecting to AWS bedrock knowledge base
Use case
In my chatbot workflow I want to call AWS bedrock knowledge base to get RAG data. I want to use the “retrieve” API endpoint.
The problem
When I try to use http request node with AWS credentials, I get authentication error. From the docs of n8n I read that currently the AWS credentials support various AWS services, including “AWS Bedrock Chat Model” but not AWS bedrock knowledgeBase
The output returned by http request node
403 - “{"message":"Missing Authentication Token"}”
As a workaround I called an AWS lambda that calls AWS bedrock knowledge base, but I wonder if there is a way to call it directly from n8n, and if not, would love to have it developed
Thanks!
