I am trying to set up a weekly payout to someone using the built-in PayPal node but I keep getting an error when I try to execute the step that sends the payment. Everything worked great in sandbox but is failing with the live credentials. The error is:
Forbidden - perhaps check your credentials?
Authorization error occurred.
I went through every suggestion offered by the n8n AI agent trying to resolve the issue but nothing worked. Here is what I’ve done:
- created a new key: the connection test was successful but the step execution was not
- confirmed that the application I created on PayPal’s developer site has permission to do payouts
- tried multiple different values for the “Sender Batch ID” none of them worked
- confirmed that the recipient’s email is a valid paypal email
- confirmed that both of our accounts are located in the US
- confirmed that my paypal email has been verified
- confirmed that my bank account has been linked and verified
- confirmed that there do not appear to be any restrictions on my account
- confirmed that I am in fact using ‘live’ credentials and that the n8n setting for the credential is ‘live’
All out of ideas here, unfortunately. All help is welcome.
“errorMessage”: “Forbidden - perhaps check your credentials?”,
“errorDescription”: “Authorization error occurred.”,
“errorDetails”: {
“rawErrorMessage”: [
“403 - {"name":"AUTHORIZATION_ERROR","message":"Authorization error occurred.","debug_id":"2067c9bd9f1a9","information_link":"https://developer.paypal.com/docs/api/payments.payouts-batch/#errors\“,\“links\”:[]}”
“httpCode”: “403”
“n8nDetails”: {
“nodeName”: “Send Money”,
“nodeType”: “n8n-nodes-base.payPal”,
“nodeVersion”: 1,
“resource”: “payout”,
“operation”: “create”,
“time”: “11/17/2025, 6:09:24 PM”,
“n8nVersion”: “1.119.1 (Cloud)”,
“stackTrace”: [
“NodeApiError: Forbidden - perhaps check your credentials?”,
" at ExecuteContext.payPalApiRequest (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@aws-sdk+credential-providers@3.808.0_asn1.js@5_afd197edb2c1f848eae21a96a97fab23/node_modules/n8n-nodes-base/nodes/PayPal/GenericFunctions.ts:75:9)”,
" at processTicksAndRejections (node:internal/process/task_queues:105:5)“,
" at ExecuteContext.execute (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-nodes-base@file+packages+nodes-base_@aws-sdk+credential-providers@3.808.0_asn1.js@5_afd197edb2c1f848eae21a96a97fab23/node_modules/n8n-nodes-base/nodes/PayPal/PayPal.node.ts:190:22)”,
" at WorkflowExecute.executeNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1093:8)“,
" at WorkflowExecute.runNode (/usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1274:11)”,
" at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:1708:27",
" at /usr/local/lib/node_modules/n8n/node_modules/.pnpm/n8n-core@file+packages+core_@opentelemetry+api@1.9.0_@opentelemetry+sdk-trace-base@1.30_08b575bec2313d5d8a4cc75358971443/node_modules/n8n-core/src/execution-engine/workflow-execute.ts:2324:11"
- n8n version: 1.119.1
- Database (default: SQLite): default
- n8n EXECUTIONS_PROCESS setting (default: own, main): default
- Running n8n via (Docker, npm, n8n cloud, desktop app): n8n cloud
- Operating system: Window 11
