📣 New category: 'Help me Build my Workflow'
Hi,
Everyone, I am new here and found it really awesome to work, and to collaborate at the same time. Loved you’r idea though :blush:
Thanks
Thanks for the support!
totally agree!
In n8n, X works by letting you connect simple building blocks, called nodes, to create a workflow. Each node does one thing like collecting data, changing it, or sending it somewhere. To use X, you just pick the right node, set it up with the options you need, and connect it with others. Once everything’s linked, n8n runs the workflow step by step, passing the data along until the whole process is done
This really isn’t the right place to post this. Instead, create your own topic in Questions .
i want to start learning n8n. no tech background. can i do it
Yes @CRM_Automates you can do it. With two months of consistency, you should gain good grounds. And there are a lot of free resources for you on YouTube.
The same here.
Hello,
I’ve noticed that a lot of posts end up in the wrong section,
For example, workflow-building requests sometimes go into Questions, while troubleshooting most of the time ends up in Help me Build my Workflow.
This overlap makes it harder to keep things organized, and since most of the activity happens in Questions (partly because of the rewards/leaderboard), that section tends to dominate anyway.
Maybe it’d make sense to merge both into one category like “Questions & Workflows” and use tags (Troubleshooting, Bug, Workflow Design, ..etc) to keep things organized, kind of like GitHub Issues.
Thank you, just sharing my thoughts!
Tags will have the same problem. But we’re looking at getting some AI assistance to auto-move topics into the right category.
good to know, u guys do i great job!
Is it at all possible to connect a workflow to my Jobber account, so that when we add or update clients & job statuses n8n will automatically update certain cells within google sheets? If so, where can I find a tutorial or workflow on that? I’ve been searching everywhere and trying to build my own but keep coming up short
Please create your own topic for this in Help me Build my Workflow
Love this! It’s much easier to get help when it’s a community effort. I’ll be sure to post any workflow questions in the right place moving forward.
Thanks this is Amazing…
Welcome to the community
Wie komme ich zum Workflow
In Python (Native) (Beta) i want to use previous node data currently i am usning _(“Node name”) but it’s giveing error like *
“error”: “name ‘_’ is not defined”
please help me
I agree on it. Would be very helpful.
